Router flashing orange after power cut
Lundy06
Message 11 of 11
We had a power cut in our area last night and since then my router hasn't worked. The light is flashing orange and I've tried all suggested solutions, ie. switching it off for 20 mins, unplugging it, and resetting it, and it's still flashing amber. Can someone help please as I rely on WiFi calling due to bad signal in my house.
10 REPLIES 10
Message 1 of 11
Hi @Sophiebanyard
Please can you create your own topic on the Community, we can then take a look at this for you.
Message 2 of 11
@Sophiebanyard
You will need to open your own thread the support staff will not answer you in another customers thread.
(TT community rule)
You  also need to add the info in  post #2  to save time.
Message 3 of 11
Hi Carl
im having the same issue after a power cut, all diagnostics and internet connections have been ran and found no fault
Message 4 of 11
Excellent, thanks for confirming.
Message 5 of 11
Hi Karl,
My new router has arrived and is working perfectly. I'm back online! 🙌
Thanks again for your help.
Message 6 of 11
No Problem 🙂
Router should arrive within 48hrs.  Connect up as soon as it arrives and let me know here.
Message 7 of 11
Thanks Karl 🙂
Message 8 of 11
Tests are clear. A new router is on the way to make sure this has not been damaged by the power cut.
Message 9 of 11
Hi Michelle,
I've done that now.
Thanks,
Sara
Message 10 of 11
Good morning,
  • Name
  • TalkTalk Telephone number or Account number
  • Alternative contact number
