Router is blocking work VPN
Haylzzx
Message 34 of 34
Hello my router is blocking my work VPN so I am unable to work from home. I have recently moved house and I am using the same router as before. I had previous problems with this in my old address but this was resolved. Perhaps the firmware needs to be updated? It is very important I am able to connect to my work VPN in order for me to work. Please help.
33 REPLIES 33
Message 21 of 34
Hi @Haylzzx
I have asked you this several times now about which VPN client you are using. V206 does fix some known VPN issues with a Cisco VPN client, other than that they all should work. I do extensive testing with all of the free VPN clients I can, prior to a new firmware release. Have you tried turning your router & ONT off for at least 30 minutes to clear any remaining sessions? That might sort out the problem.
Message 22 of 34
Thank you Ferguson. I have no idea tried to call my I.T department but they aren’t there until the new year. Had this issue before previously in old house and they managed to send another router and it worked but hopefully they can just update firmware.
Message 23 of 34
You are unlikely to get an update for a couple of days. Can you advise which VPN client your employer is using?
Message 24 of 34
Any updates on this please?
Message 25 of 34
As I said in my post #6:-
The VPN client is down to you to find out as it will have been installed on the device that you are trying to establish a VPN connection from.
I cannot possibly know that as it is not my device. If it was provided by your employer, then you will have to ask them.
Message 26 of 34
Sorry Keith where do I find that please?
Message 27 of 34
Thanks, what about your VPN client on your device that I have asked for before?
Message 28 of 34
206
Message 29 of 34
Hi @Haylzzx
You have either the Sagemcom 5364 or the 5464 router, they use the same firmware, so it doesn't matter which one you have for now. If you go to the router login page (HTTP://192.168.1.1), there is no need to login, just look at the bottom left of the page. The firmware (they call it Software) is listed there. All I am interested is the last three digits from the right, e.g. 174 or 206.
Message 30 of 34
Hi Karl,
Thank you for replying I have updated the profile I believe. It may show that its disconnected though as I have moved property. I am yet to be given a new account number.
Message 31 of 34
Can you please update your Community Profile to include your
  • Name
  • TalkTalk Telephone number or Account number
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
Message 32 of 34
Thanks for replying Keith, where can I check all that info? The router I have is sagemcom
Message 33 of 34
Please can you confirm the make/model of the router you have & the firmware version that it is currently running? What VPN client are you using?
