on 09-08-2024 03:29 PM
I believe this issue has been raised in previous posts but not sure how to remedy. I keep finding several of the devices connected to the 2.4GHz band are losing internet connection (Ring doorbell, Podpoint etc.). This is happening about almost every 24hours, reset the router and they come back online only to drop off again a few hours later. Have tried factory resets, no joy. When the devices go offline, they still appear to be connected to the router, they just lose internet connection.
I have read in previous threads that it is a good idea to have TalkTalk disable the WiFi optimizations, is this something that can be requested on this forum?
on 14-08-2024 01:03 PM
That is certainly not the correct way to extend a WiFi 5 router anyway. You could try channel 1, but unless you have WiFi Optimisation disabled, it may move you back to channel 11 again. Let me have a word with TalkTalk to see if they can offer anything better.
on 14-08-2024 12:59 PM
Hi Keith,
The extender model is TP WA850RE which I believe is 2.4GHz only. I have powered off for now to see if it makes any difference. Is there benefit to moving to channels 1 or 6 due to channel 11 interference (these other devices are not mine so can't do anything about them)?
Firewall is still set to medium.
on 13-08-2024 10:01 PM
The firewall needs to be on medium & will not be the issue (unless you have changed it). The extender is part of the issue, at least, and is obviously old as it only seems to work in the 2.4GHz band, but I have no idea of its make/model. There are also other networks on channel 11 that are interfering with yours namely SKY01FF7 and BT-R6F6Q8 and an EE-WiFi network whose BSSID is "7A-A2-37-8D-21-C8".
on 13-08-2024 06:01 PM
This is a laptop. This does not suffer from internet connection issues, the problem is with fixed devices (Ring, Chime and EV charger) on the 2.4GHz band losing internet after ~24hours.
Router has a pretty good line of sight (especially to the Ring device which is one of the problem devices). Could it be a firewall issue?
on 13-08-2024 03:22 PM
Hi @rhbarnes1
What sort of PC is this a tower case or a laptop etc? If a tower case is the WiFi card a PCIe one where the antennae are down the back of the case? In that situation, the metal of the tower case can block WiFi signals. It can be beneficial to get some extension cables to move the antennae away from the rear of the case, this might help.
Try to keep both router & PC away from:-
Where USB or PCIe-connected WiFi adapters are concerned, power management is best disabled if running in Windows to keep a reliable Wi-Fi connection working at full speed. Once you have made the changes outlined below, it is probably best to restart the PC.
Windows Power Management issues. To check this in Windows 10 or 11, open Device Manager and expand Network adapters. Then right-click your WiFi card & select Properties. Next, click on the Power Management tab and untick Allow the computer to turn off this device to save power. If the adapter is connected via USB, then expand the USB section in Device Manager and the same option can be found in the Power Management tab in most Root Hubs and USB Controllers. Untick it in there as well.
13-08-2024 11:47 AM - edited 13-08-2024 11:48 AM
Some initial findings then.
Your network adapter is connected to the 2.4Ghz band, not the 5GHz one, so your speeds will never be much good. You have an extender of some sort that is using the same channel within the 2.4GHz band as your router (channel 11). This is interfering with your router & I would suggest that you turn it off, unless you can force that to use a different channel ( 1 or 6). Despite what you say that the 5Ghz is fine, it has a very low signal strength wherever the PC & router are located.
Perhaps you can tell me roughly where in your property the router & PC are located (ideally in a PM to preserve your privacy)?
on 13-08-2024 11:41 AM
OK don't worry about that, I have worked out your network name.
on 13-08-2024 11:28 AM
Which WiFi network is yours?
on 13-08-2024 11:18 AM - last edited on 13-08-2024 11:27 AM by KeithFrench
Keith,
WiFi Scanner zip file attached. Just to recap, 2.4GHz seems to work for ~24hours and then all devices on it lose internet connection and requires router reboot to fix. 5GHz seems fine.
Thanks & regards
on 10-08-2024 03:26 PM
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
on 10-08-2024 03:24 PM
Hi Keith,
Thanks for the reply and please send the guide. The devices connected on 5GHz seems fine, the issue is with all devices on the 2.4GHz; they all lose internet connection at same time and a power off-on of these devices does not fix the issue, only a router restart seems to work. The devices still appear to be connected to the router as they appear listed when I log into the router so it seems to be a router internet connection on the 2.4GHz. The router LED remains illuminated white. I have tried moving the 2.4GHz to channel 1 (from 11) but this has no effect. Unfortunately, the devices on the 2.4GHz do not support 5GHz so I can't move them across.
Any advice much appreciated.
on 09-08-2024 03:36 PM
It used to be, but cannot be done currently. It is important to find the actual cause of your problem & fix that, rather than just guessing.
