Substituting supplied TalkTalk Eero 6 router
MikeGardy
Message 9 of 9
I have recently tried to swap out the supplied TalkTalk Eero 6 router with my own Eero Pro 6E router. This was not successful, despite following the Eero app  procedure.
Am I missing something here, or is it a case that the router has to be pre-registered with TalkTalk first?
Kind Regards, Mike Gardener.
8 REPLIES 8
Message 1 of 9
Wonderful news, take care. Thanks😄
MikeGardy
Message 2 of 9
Thank you all for your support and quick replies. I ended up doing a hard reset of the routers and deleted the network from the Eero app. I then recreated the network and added the Eero Pro 6E as the gateway. After running a speed test, I then added the Eero 6 and Eero 6 extender.
All works fine now and I have much better coverage throughout the house.
Thanks again.👌
siphosethu-TT
Message 3 of 9
Thank you. 😇
Message 4 of 9
No problem @siphosethu-TT, hopefully I can help.
siphosethu-TT
Message 5 of 9
Hi there @KeithFrench, here's more help I guess @MikeGardy. 🙃
Message 6 of 9
Hi @MikeGardy
Can you explain what you did in the app and what went wrong? Then, I might be able to help you.
siphosethu-TT
Message 7 of 9
If you are still having issues, then please contact our full fibre team and they will give you a hand in setting it up. Thanks
03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
You can use the number or the chat link below. 😇
https://community.talktalk.co.uk/t5/FutureFibre/bd-p/FutureFibre
siphosethu-TT
Message 8 of 9
Hi there @MikeGardy, please try using the following link directing you to a page with instructions on how to set up your Eero. Thanks
Setting up your eero
