Super Router
JaceyBoy
Whizz Kid
Message 18 of 18
Having issues with my super router again, says we have internet connection but no internet, doing it on a few devices, have reboot and even factory reset a couple of times but it is stil doing it after a few days, anyway to find out if its had it?
Jason
17 REPLIES 17
Message 1 of 18
Hi JaceyBoy
Ok no problem 🙂
Message 2 of 18
It’s not the drop of connection through the cable, it’s more from devices to router, like Ring camera etc which led me to believe it was the router acting up, but it’s settled now, I will monitor and let you know if any more problems
Jason
Message 3 of 18
Hi JaceyBoy
If the connection does continue to drop then please let us know and we can arrange the engineer visit for you.
Have you tried the router directly at the test socket?
Message 4 of 18
Hi Debbie,
no it’s ok so far, the old router is back in and working fine, so will post back the new one which was sent out….
Jason
Message 5 of 18
Hi JaceyBoy
The line tests are clear but I can see re connections.
Would you like me to arrange an Openreach engineer visit to the property?
JaceyBoy
Whizz Kid
Message 6 of 18
Hi Debbie, I have connected the old router and now having the same issues of connection again, can you check my line for faults please as the TalkTalk account screen tells me there maybe a fault with my Fibre?
Jason
JaceyBoy
Whizz Kid
Message 7 of 18
Hello Debbie, I have tried and tried to set the new router up (although refurb) and the old one is better, so keeping with that!
Jason
Message 8 of 18
Hi JaceyBoy
This would be need to be returned if it's a Sagemcom sorry.
JaceyBoy
Whizz Kid
Message 9 of 18
No its a Super Router Sagem?
Jason
Message 10 of 18
Hi JaceyBoy
If its a WIFI hub then this will need to be returned otherwise a charge will be applied for un-returned equipment.
If it's a HG633 or DLink 3782 then you can keep hold of this.
JaceyBoy
Whizz Kid
Message 11 of 18
Will do Debbie, can I keep the old router as a backup at all?
Jason
Message 12 of 18
Hi JaceyBoy
That's great, please let us know how you get on.
JaceyBoy
Whizz Kid
Message 13 of 18
Yes I have thanks, I will setup later
Jason
Message 14 of 18
Hi JaceyBoy
Message 15 of 18
Hi JaceyBoy
Thanks for your reply. The router is on its way, please allow 24-48hrs for this to arrive.
Thanks again.
JaceyBoy
Whizz Kid
Message 16 of 18
Yes please Debbie
Jason
Message 17 of 18
Hi JaceyBoy
I'm sorry to hear this. I think we should send a replacement router.
Are you happy for me to arrange this?
Anonymous User
