TP-Link Archer T3U Wireless Adaptor will not connect 5GHz
JohnG1973
Message 3 of 3
TP-Link Archer T3U Wireless Adaptor will only connect 2.4GHz on channel 11.
We have the EERO Pro 6 routers which don't appear to be able to be configured.
Any help would be appreciated.
John
Chris-TalkTalk
Message 1 of 3
Hi John,
How are you getting on?
Message 2 of 3
If you look in the Eero app under radio analytics I think it is, what 5GHz channel is it using?
