on 15-11-2023 12:55 PM
Myself and several other people where I work are having issues connecting with TalkTalk when working from home now. When I use my phone as a hotspot and switch to Mobile Data it works fine. Our IT department have confirmed only TalkTalk (and companies using TalkTalk network) customers are affected and that we need to individually contact our ISPs to get this resolved. They have tried clearing cache etc and it hasn't worked.
When trying to load the web app we use to log in, it's saying
"Hmmmm... can't reach this page
openuni.via.aspect-cloud.net took too long to respond
Try:
Checking the connection
Checking the proxy and the firewall
Running Windows Network Diagnostics
ERR_CONNECTION_TIMED_OUT
I can confirm the laptop can still connect to the router and can use everything else like Edge, Skype, Teams etc with no issues. It's just when trying to use the main web app we need to use to log in, which I can't work without.
Please can this be looked into as soon as possible as this is preventing me working.
on 08-12-2023 06:19 AM
Hi Egnot18,
Please can you create your own topic and we'd be happy to look into this for you.
on 07-12-2023 09:36 PM
Hi. We have the same issue with St John Ambulance connection. Is there a solution to this we can throw at the SJA IT team?
on 16-11-2023 08:33 AM
Just had an update from Networks. They have advised connection s failing at the web host. Tested from other Networks and they are seeing a failure at the web host end, can you ask your IT Teams to contact the web host directly.
on 16-11-2023 07:49 AM
can you try the site now and see if you can access.
on 15-11-2023 03:26 PM
And this is what I get when I traceroute it (it fails to get there...)
[gmllaptop]: traceroute openuni.via.aspect-cloud.net
traceroute to openuni.via.aspect-cloud.net (185.130.100.163), 30 hops max, 60 byte packets
1 asus (192.168.1.1) 1.272 ms 1.212 ms 1.346 ms
2 81.1.112.76 (81.1.112.76) 130.834 ms 131.689 ms 131.660 ms
3 ae51-ner001.mlk.as13285.net (78.144.1.25) 131.919 ms 136.523 ms 133.748 ms
4 ae51-scr102.thw.as13285.net (78.144.1.24) 136.463 ms 136.441 ms 139.081 ms
5 ae64-scr101.thw.as13285.net (78.144.1.134) 139.385 ms ae60-scr101.thw.as13285.net (78.144.1.110) 140.437 ms ae64-scr101.thw.as13285.net (78.144.1.134) 141.023 ms
6 Opal-ge-2.2.0.mpr1.lhr2.above.net (213.161.78.209) 140.468 ms 140.432 ms 139.790 ms
7 * * *
8 ae9.mpr1.lhr23.uk.zip.zayo.com (64.125.28.3) 70.892 ms ae11.mpr1.lhr23.uk.zip.zayo.com (64.125.28.33) 70.862 ms 71.128 ms
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
on 15-11-2023 03:24 PM
FYI, you should "tracert openuni.via.aspect-cloud.net".
It's tracing a route to the server, not a URI on that server.
on 15-11-2023 02:18 PM
Thanks, I'll pass this to my colleague now.
on 15-11-2023 02:16 PM
Hi Karl, I wasn't able to message it directly. Please see traceroute below
traceroute
on 15-11-2023 01:33 PM
Can you perform a traceroute and send me with the details please.
My colleague has raised a ticket to Networks for this, and we want to include as much info as possible.
on 15-11-2023 01:19 PM
Hi Karl,
I've just added my landline number and account number to my Community account.
on 15-11-2023 01:06 PM
Can you please add your home phone number or Account number to your Community Profile.
We will not attempt to call you, this is so we can locate your account and run tests on your line if you are reporting a fault.
We will then reply via this thread in our Community with any further advice or next steps.
If unsure of your phone number, and if your line is working simply dial 17070 from your land line phone and this will confirm the number for you. Alternatively these details can be found within My Account online or may be on the heading of any paperwork you have received.
Please post back on this thread when this has been done.
