Told I need two eero devices for full fibre 900?
Djmcf
Message 16 of 16
I've been told I need two eero devices to mesh and give me my full fibre 900? This doesn't sound right to me as I thought the mesh was only for wireless signal? Why would I only get 220mbps down and 800 mbps up over Ethernet cat8 on a single eero 6 pro? Surely it's just a gateway to the full fibre? How could that be solved with mesh?
15 REPLIES 15
Message 1 of 16
Message 2 of 16
Perfect, thank you so much Chris for the help it's greatly appreciated.
Message 3 of 16
I've ordered the router eero, it should be with you within 5 working days.
Message 4 of 16
That would be great thanks Chris, seems like the natural next step in troubleshooting.
Message 5 of 16
OK, I can send another eero out to test with, would you like me to arrange this?
Message 6 of 16
I am indeed, every device I have tried with all my different cable combinations has failed to get higher than 220-250. Some are far lower than that, I'm seeing download speeds as low as 150-40.
If I get to within 2m with line of site of Eero I can connect on wireless and I'm seeing 110 down with again 700 up.
Message 7 of 16
OK thanks, speeds at the eero look fine. Are you experiencing slow Ethernet speeds on more than one device?
Message 8 of 16
That should be all done now thanks
Message 9 of 16
Hi Djmcf,
  • Name
  • Telephone number
  • Alternative contact number
paulshent
Message 10 of 16
Who told you that you need 2 Eero units  ?
Ok. I have 500 full fibre and i get that at the first eero. More so using ethernet, and also with a very good capable wifi dongle connected to usb 3.x
The 900 package does come with 2  Eero and gives great coverage. But i find that one (1), will do the job . So i would say that on 900 meg fibre, that one Eero is enough and will work.
Message 11 of 16
Hi there thanks for replying
I get 9.3 Mbps down and 8.5 mbps up when connected directly to the ONT no matter which ethernet cable I use (all of them CAT 😎
When the Eero 6 pro is connected it and I check the speeds through the app while staying within 2m so I can actually connect it says I'm getting 900ish up and down. But like I say I'm only getting 220 down but 900 up when wired into the Eero.
Anytime they've done a line test it's come back ok apparently.  But I've been lied to ignored or fobbed off so many times by now I can't believe them for a second
Message 12 of 16
I'm sorry for the delay. What speeds are you seeing if you connect directly at the ONT with the eero removed and run a wired speed test?
Message 13 of 16
Yeah I thought so, it was installed on 3rd of may and I called straight away after set up to say my wireless range was only about 2m even with line of sight. Never mind the ethernet speeds. Long story short I think this router is faulty but after numerous calls and 6 weeks this is where I'm being sent basically an extender.
NoitchNige
Message 14 of 16
My Eero 6 pro works fine  @900 mbps  now the cable to the house been replaced . I'm not sure why you have been given that info?
When it's working it's fast.
Good luck
Djmcf
Message 15 of 16
Also I'm on ethernet because my eero 6 pro has a WiFi range of 2m
