UKTV Play constantly buffering
MaureenK
Message 11 of 11
I have recently moved to Talk Talk Full Fibre 150, and since then have been unable to watch the UKTV Play App on my Sony Bravia smart tv without constant buffering.  Have tried switching off the Eero router, together with switching off TV fully but with no success.  I noted an older post similar to mine which suggested disabling Add Blocking, but this has not helped either.  Can anyone help at all.  Thanks.
Maureen Kennedy
10 REPLIES 10
Message 1 of 11
Hi Maureen,
Are you having issues with other devices connected ?
Do you have any device wired to the eero, PC or laptop etc ?
If you run a speed test from your devices, what speeds are you seeing ?
Message 2 of 11
Have a look at the help article here. It works through various options, depending on which type of Bravia model you have.
MaureenK
Message 3 of 11
Hi Michelle
Have tried the suggestions made by Karl ,but still no success.  The Apps are pre-installed on TV, so unable to remove and re-install.
Don't understand why I am unable to view easily now on this App.   Feel that the speed I receive with the Eero App is insufficient.  Have already spoken to Tech Team by phone to discuss that connection cuts out at times when using Apps on my phone when I am in my kitchen at home.  Have to wave my phone about in the air to pick up the signal again.  Tech team advise that the Eero router should be sufficient for the size of my home.  As I have mentioned before I was a BT Halo customer prior to my move to  Talk Talk, and to date I have been disappointed that Talk Talk Full Fibre 150 does not match the BT service at all.  I appreciate that I have received a £42.70 credit to my account  but feel I am not going to receive the level of speed I had hoped for.
Maureen Kennedy
Message 4 of 11
Morning Maureen,
How are you getting on?
MaureenK
Message 5 of 11
Thanks Karl - will give your suggestion a try tonight.  Appreciate all suggestions.  Thanks again.
Maureen Kennedy
Message 6 of 11
If it's only the UKTV Play app affected, then it must be app related rather than an issue with the broadband etc.
Have you tried turning off the eero and the ONT box on the wall for 30 minutes.  This will clear the session.
Also, if this option fails to resolve, can the UK TV play app be removed and then reinstalled on the TV.  Not sure if this is a pre installed app on the Bravia.
MaureenK
Message 7 of 11
Hi  thanks for replying.  It is only UKTV  Play that is causing problems.  All other Apps are playing perfectly.
Maureen Kennedy
Message 8 of 11
Hi MaureenK
Is it only the UKTV Play App that is affected.  If you try any other on demand apps such as Iplayer, ITVX etc etc , do these also buffer or play ok ?
MaureenK
Message 9 of 11
Have updated as requested.
Maureen Kennedy
Message 10 of 11
Have you checked your Eero app to see if there are any updates pending?
I had something similar with another app and when I updated it worked fine. Not sure why an outstanding update should affect anything but it's worth a try.
Not sure how the Sony TV apps work, but is the app up to date?
Is there anything similar on the Sony Forum regarding Apps buffering? It may be worth a look in case it's TV related.
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
