VDI Client (Java Applet) being blocked
andrewismith
Message 47 of 47
My wife works from home for NHS her laptop bring up a java applet for a VDI Client login, when she tries it while connected to a mobile hotspot it's fine, on wi-fi or ethernet it doesn't. Is there anything blocking VPN or VDI Client on my service?
I'm on Future Fibre. Thanks.
Andy.
46 REPLIES 46
Message 41 of 47
Hi Andy
Are you using the eero or WIFI hub router?
Message 42 of 47
Yes that's the number assigned to my account, in on Fibre 900 VoIP. Shall I message you my account ID?
Andy.
Message 43 of 47
Hi andrewismith
Have you added the correct number? (I'm unable to locate any details) Do you have a FTTC or FTTP connection?
Message 44 of 47
Profile updated Debbie, thank you.
Message 45 of 47
Hi Andy
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Message 46 of 47
Which make/model of router do you have and what firmware version is it using? Which exact VPN client does your wife use
