04-10-2023 02:32 PM - edited 04-10-2023 04:21 PM
My wife works from home for NHS her laptop bring up a java applet for a VDI Client login, when she tries it while connected to a mobile hotspot it's fine, on wi-fi or ethernet it doesn't. Is there anything blocking VPN or VDI Client on my service?
I'm on Future Fibre. Thanks.
Andy.
on 05-10-2023 09:56 AM
Hi Andy
Are you using the eero or WIFI hub router?
on 05-10-2023 09:55 AM
Yes that's the number assigned to my account, in on Fibre 900 VoIP. Shall I message you my account ID?
Andy.
on 05-10-2023 09:50 AM
Hi andrewismith
Have you added the correct number? (I'm unable to locate any details) Do you have a FTTC or FTTP connection?
on 05-10-2023 09:46 AM
Profile updated Debbie, thank you.
on 05-10-2023 08:45 AM
Hi Andy
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
on 05-10-2023 08:42 AM
Which make/model of router do you have and what firmware version is it using? Which exact VPN client does your wife use
