VOIP has stopped working
CyrilH
Message 19 of 19
Recently changed my broadband/phone package to full fibre. Current set up is as follows:
- ONT to Eero
- Eero to netgear switch.
- Grandstream voip to switch.
My phone worked well until today. Can't make or receive any calls although there is a tonality. I have tried resetting the router and the grandstream to no avail. Also plugged the grandstream straight into the Eero to check the connection. Same issue.
Spoken to talktalk who talked me through a few things but that didn't work and the issue has now been "escalated".
Meanwhile, if someone has a brilliant idea or have been through a similar problem and got it fixed, it would be great if you could share how you got things fixed.
Many thanks
18 REPLIES 18
Message 1 of 19
Hi CyrilH
Our engineers have identified the problem and are actively working to deploy the fix. We expect this to automatically update on your equipment in the early hours of the morning and your normal service to resume. We sincerely apologise and understand the inconvenience this has caused. Thank you for your patience whilst we have worked to resolve this issue.
Please can you retest?
Message 2 of 19
Our Service status page has now been updated
We are aware customers with FTTP services are currently experiencing issues making and receiving calls, our engineers are aware of the issue and are working hard to a resove this. We will provide any updates here, we apologise for any inconvenience this is causing.
Service Status | TalkTalk Help & Support
Message 3 of 19
Thank you.
Will you be sending someone over if you cannot fix the issue remotely ?
Many thanks
C
Message 4 of 19
Hi CyrilH
Our Network/Incidents Team are looking at this now and I will post back as soon as I have further information.
Message 5 of 19
Profile updated.
C
Message 6 of 19
  • Name
  • Telephone number
  • Alternative contact number
Message 7 of 19
Sadly it is not working.
Although I have a mobile phone, the reception is patchy and I really need access to my landline.
Would it be easier if you sent a tech over ?
Many thanks
C
Message 8 of 19
Hi CyrilH,
If you could try this again please, power down the eero and also factory reset the DVA and please let us know if there is any change please.
Message 9 of 19
Hi David,
I'm sorry to hear this. Please can you create your own topic and we can investigate this further for you.
Message 10 of 19
Yes. Did it yesterday. Not since though.
C
Message 11 of 19
Thanks for the guidance, Michelle.
I have now done factory resets of the TT Wi-Fi Hub** - it's not an eero - and the DVA**. I then switched everything off and back on again, but unfortunately nothing has changed: calling my mobile results in either disconnection after a few seconds or immediate 'unobtainable' beeping; calling the landline from my mobile results in silence then a double beep and disconnection.
So what next, please?
David
** By the way, not to my surprise the user guides for the these devices, say the reset must be done with the power ON.
Message 12 of 19
Hi DGEC4,
Can I just confirm, did you also do a factory reset of the digital voice adapter? (DVA)
Message 13 of 19
Good morning, Michelle (or colleague)
My situation is almost exactly the same: no incoming calls and attempted outgoing calls either drop out few seconds after being answered or are immediately blocked by a continuous beep.  On the Service Status page last evening the 'fault notice' update said the incident had been resolved, that there wasn't the case then and isn't now. I've tried switching everything off and back on several times last night and this morning, frustratingly to no avail, which is causing me serious problems that need to be resolved URGENTLY, please! The TT system couldn't do a line check, apparently because as well as VOIP the old (unrelated) analogue cable is still present in my house. Thanks - David
Message 14 of 19
Hi again,
I was just about to post back on your topic as the team have just advised us the following,
We’re aware that some Full Fibre Digital Voice (VoIP) customers are currently unable to make and receive  calls.
Latest update: 08:10am 13th December 2023
Service has been restored, we recommend if you're still being affected, to power down both the eero router and the Grandstream digital voice adapter and use the factory reset pin, this will clear the issue.
Message 15 of 19
Hi Michelle,
Still not able to make calls.
Spent some time with tech support yesterday and tried pretty much everything, from disconnecting, resetting, swapping phone etc.
Would you be able to send someone over to have a look ?
That aside, fibre internet works well but I do need access to a landline.
Many thanks
C
Message 16 of 19
Good morning,
This incident has now been resolved. Is your VOIP service now working ok?
Message 17 of 19
Thanks Chris,
Thanks for taking the time to respond. I was not aware an incident had been reported.
Will wait until it is resolved before switching the ONT off in case I have no luck.
All the best
C
Chris-TalkTalk
Message 18 of 19
Hi CyrilH,
You could try switching the ONT off for 30 minutes and then switch back on and retest, but an incident has been raised for problems making and receiving calls on VoIP, please find details and update here - Service Status | TalkTalk Help & Support
