Voip sagem Router
silverbird63
Super Duper Contributor
Message 16 of 16
I have the router hub2 but the router keeps flashing from white to amber, the BT engineer says it should remain solid. We have Internet access  but can be unstable on my older mobile but good in hubby. Should it flash amber. We had a new one sent and it does the same, but the original one stays solid blue. Very strange.
Thanks in advance
Not an expert at much just like to learn about as many things as I can
15 REPLIES 15
Message 1 of 16
OK thanks. Could you switch your router and the ONT off and leave them off for at least 30 minutes, then switch back on and check to see if the router still continues with the same behaviour - please let us know how you get on
silverbird63
Message 2 of 16
We can’t identify your router
We’re sorry, we can’t identify your router or it’s software version.
My account is telling me this.
silverbird63
Message 3 of 16
Hi Chris.
We are using all the cables that came with the router and the engineer connected it all to make sure everything was connected correctly.
Message 4 of 16
OK thanks. Are you using the cable provided with the new router?
silverbird63
Message 5 of 16
Hi Chris.
This flashing is constant.
The engineer from Openreach stayed for an hour checking the connection and it was flashing constantly. He said there is an issue with the router. Tech team sent a new one yesterday and it is flashing constantly again.
Message 6 of 16
That's strange, so the connection seems stable but the light flashes white/orange? You say it flashes every 30-60 seconds does it only flash a couple of times and then goes back to solid white/blue?
silverbird63
Message 7 of 16
Hi Chris.
We do have internet connection but it keeps flashing every 30 to 60 seconds.
Message 8 of 16
And you have no internet connection when the light is flashing?
silverbird63
Message 9 of 16
Hi Chris.
Early message incorrect.
Account doesn't recognise router.👍
silverbird63
Message 10 of 16
Hi Chris.
It is flashing as we are chatting.
Message 11 of 16
The router appears to be connected to the Internet at the moment, is the light flashing now?
silverbird63
Message 12 of 16
Thanks. The new wifi hub2 is flashing constantly and this is the 2nd one we have received. We used the original wi fi hub for faster fibre and that stays solid blue/white. When we view the acct and perform a connection test it says Talk Talk does recognize the wifi router.
Thank you
Message 13 of 16
Hi silverbird63,
It flashes when first connecting but should stay solid white/blue once connected to the Internet. Does it flash repeatedly?
silverbird63
Message 14 of 16
Thank you Michelle the connection on other devices is ok. Just mine is an older mobile. The Q is should the router be flashing?
Message 15 of 16
Good morning,
I've included a Help Guide below. Just to confirm, is your connection stable on all other devices but not the phone?
Router Flashing Orange | Wi-Fi Hub | TalkTalk
