WIFI Distance Poor with new Fibre 500 Voip and Eero router
zedhower
Message 8 of 8
I just upgraded to the  Fibre 500 Voip with Eero router which is absolutely fantastic but the WIFI only goes to the next door room , the old router I used to have would go all over the house. Are there any WIFI extenders you recommend for the Eero router?
Tim
Leslie Goodman
7 REPLIES 7
Message 1 of 8
@Roger1966
If you would like help here then please start your own topic.
Roger1966
Message 2 of 8
Literally same problem Leslie
Message 3 of 8
Hi Michelle,
Unfortunately I didn't keep my old router, I sent it back in the blue bag you provided to return old equipment
Tim
Leslie Goodman
Message 4 of 8
Hi Tim,
Ok thanks for confirming. Does your previous router still work with your FTTP connection?
Message 5 of 8
Hi Michelle,
I just have the one Eero router that came in the box.
Tim
Leslie Goodman
Message 6 of 8
Hi Tim,
Can I just confirm, how many eeros do you currently have?
Message 7 of 8
Which router did you have previously, have you tried that with your new connection? The eero is very much designed as part of a mesh system, which is likely to require additional units for best coverage. The support team will advise further when they are back online from tomorrow.
