on 20-11-2023 02:02 PM
Hi. I have just upgraded to the Full Fibre 150.
Instillation fine. Modem provided fine. Connection by ethernet cable fine.
Wifi connection dreadful.
Only casts about 4 meters. Live in a small flat. Previous modem was not great but better than Eero 6.
Have raised complaint with Talk Talk but they just recommend I pay more and get Total Home so they can send me another modem to mesh.
I really feel let down by Talk Talk. I have upgraded my contract and been given a service that is not fit for purpose. i.e here is your new service but it is no good so upgrade and pay more!
I understand that they do not want to be handing out extenders to everyone who has complained about weak wifi but from my point of view this is the only option for selling a package that does not work even in a small flat.
Finally if they had said at point of sale that I would probably need to pay for a mesh I would have gone with a different provider as I was in the process of leaving when they offered me this package.
on 22-12-2024 09:54 PM
Hi @Curt0o
If you want help, you cannot use someone else's thread.
To get help, you must start your own thread. To create your own thread, go to the main page for the board in question & click the "Start a topic" button. Then please @ mention me into that thread & I will be happy to help you.
TalkTalk insists on one thread per problem per customer. Please note, TalkTalk makes the rules, not me.
22-12-2024 05:59 PM - edited 22-12-2024 06:11 PM
Curt0o - I have the same problem since 'upgrading'. So slow in the room next door, I can't even do an internet speed test
@Curt0o To save time follow the instructions below by Keith French (posted in post #18)
on 22-12-2024 04:59 PM
on 04-09-2024 11:47 AM
Many thanks Keith, will do as you suggest now.
on 03-09-2024 09:56 PM
Hi @DavidL44
I do not send it out without reason & not without a thread in progress. If you want help, you cannot use someone else's thread.
on 03-09-2024 07:23 PM
@KeithFrench please can you send me a copy of your guide? I can see you have helped so many people on this thread, I need your advice as well! thank you so much, very grateful for any assistance you can offer me...
on 10-06-2024 04:34 PM
@KKK48, unfortunately your advice will date quickly, as copper will no longer be maintained.
Better that people take advantage of a free upgrade when Talktalk offers it.
on 05-06-2024 01:03 PM
I had full fibre installed last year.
The installer told me I cannot have a router in a similar place to the old standard router as they couldn’t run the cable through my garage. Only option was to install it at the front of the house. The result of this was the range of the Wi-Fi gave me 80mbps
for 60% of the house but where I really need it in my study, dropped to 1.5 mbps!
12 hours of calls to TalkTalk and 2 free extender’s later I extended my own Ethernet cable and purchased my own extender as the TalkTalk ones were hopeless.
Talktalk at one point offered me an Eero mesh but at higher cost to me!
I even asked to return to copper cables but they will not do that.
My advice to those who are offered full fibre is DON’T!
on 25-03-2024 09:26 AM
My apologies jez. Is your connection still currently ok?
on 25-03-2024 09:17 AM
@Anonymous, jezSmith is the original poster.
@ClaireT2, you need to start your own thread for support from staff.
on 25-03-2024 09:11 AM
I can't know what may be the reasons for your signal problems, but I used my old talk talk modem and bought a second hand eero which has created a "mesh" that seems to work. 3 modems to cover a 2 bed flat.
I do put most of my signal problems down to my many walls the signal has to pass though my experience of the eero is that it is best used as a mesh with multiple units.
I suggest looking at info about the eero before deciding.
on 25-03-2024 06:58 AM
Hi jez,
Please can you create your own topic and we'd be happy to look into this for you.
on 22-03-2024 06:49 PM
Thanks for the offer. I tried many options but it is well known that the modems don't cast very far. I would say that I have a Victorian flat and it has to pass through multiple lime plastered wall which has always blocked the signal.
I am happy with the set up. Would prefer another eero but was told I would have to pay talk talk .
on 22-03-2024 05:46 PM
I suggested above that I just bought another as many do. Can get second hand and does not have to be latest to mesh. I also used old modem from talk talk. This works but bit silly having contract with just 1 moden
on 22-03-2024 05:41 PM
I ended buying a second eero as well as using my old modem from talk talk which has a stronger signal. You end up with 2 logins but managed to cover the house. bit mad selling contract with one mesh modem as they need to mesh. This suggests more than 1 is used.
on 22-03-2024 02:50 PM
Hi @ClaireT2
I am sure I can help you, but If you want help, you cannot use someone else's thread.
If when you have created your own thread, please @mention me in on it & I will try & resolve your issues for you.
on 22-03-2024 02:16 PM
I'd be really interested in hearing if this got sorted, I am in the same position. Got Fibre 150 and an Eero and the coverage is terrible. I'm in a two bedroom flat and it barely reaches our of the room the Eero is in. When I complained I was asked to upgrade
Not sure what to do now whether to buy a booster or eero to try and spread the signal or if that is good money after bad.
WOuld appreciate any suggestions on what best to do!
Claire
on 21-11-2023 11:35 AM
Hi jezSmith,
I can see that Keith has kindly offered to help. Could you also please switch the ONT and eero off for 30 minutes then switch back on and let me know when you've done this
on 21-11-2023 11:06 AM
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
Whilst the Eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional Eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
on 20-11-2023 03:28 PM
Hi Karl. I have added these though could not see any fields for it so have put in "other" field
