error code 502
Barrowman
Message 43 of 43
“Hi, my website is showing a 502 Bad Gateway error when I turn on my laptop. Is it  possible to check if the server is down or if there’s a misconfiguration on your end?” I get the same message on my iPhone.
I'm an 81 year old if anyone can help in laymens terms it would be appreciated. Thank you. Oh, and I have full fibre 150.
Barrowman
42 REPLIES 42
Barrowman
Message 21 of 43
Sorry, missed seeing your post yesterday as I had to go out. I'm at home now if thats any good...
Barrowman
Message 22 of 43
I'm having system issues I my end when accessing my account, will just run checks on this. Please confirm if you are currently at home? Thanks
Barrowman
Message 23 of 43
Still the same....☹️
This site can’t be reached
DNS_PROBE_POSSIBLE
Barrowman
Message 24 of 43
No problem, please reboot the devices and try accessing the links again. Thanks😇
Barrowman
Message 25 of 43
I've gone one better, I've completly uninstalled it. I'll re-install when I need it again.
Barrowman
Message 26 of 43
Can you block the one you've had for 3 years to test if maybe that's the cause. Thanks
Barrowman
Message 27 of 43
Hi, yes I have Adblock+ I've had that for three years now without a problem, also the add blocker
that comes with the eero system...
Barrowman
Message 28 of 43
Hi there @Barrowman, I'll need you to check if you have any ad blockers installed on your devices as that too can be the course. I'll be investigating in the meantime on my end while you check on that. Thanks
Barrowman
Message 29 of 43
Hello again. Sorry it's been a while as I had to wait for help from my son. he has tried all you surgested but
was unable to resolve the issues, the only thing he couldn't do was to reset the bios to the default setting
as that did not appear as you surgested it would when entering the default settings page.
Barrowman
Message 30 of 43
Thank you for providing the additional information. The message "CMOS checksum is invalid - CMOS reset (502)" typically indicates an issue with the BIOS settings on your PC, which can be related to the CMOS battery. This battery helps retain BIOS settings when the computer is powered off.
Here are a few steps you can take to address this issue:
Check the CMOS Battery: If your PC is older, the CMOS battery may need to be replaced. This is usually a CR2032 battery located on the motherboard.
Reset BIOS Settings: You can try resetting the BIOS to its default settings. This can often resolve checksum errors. You can usually do this by entering the BIOS setup during startup (often by pressing a key like F2, DEL, or ESC) and selecting the option to load default settings.
Update BIOS: If the problem persists, consider checking for a BIOS update from your motherboard manufacturer’s website. An update can sometimes resolve underlying issues.
If you're not comfortable performing these steps or if the problem continues after trying them, please let me know, and I can assist you further.
Thank you, I look forward to helping you resolve this issue!
Barrowman
Message 31 of 43
Good morning. Yes The problem has not been resolved.
A bit of extra info just got this morning.....
"CMOS checksom is invalid - CMOS reset (502)"
Perhaps you could advise if this may be a problem with my pc. Thanks
Barrowman
Message 32 of 43
Hi there, please let me know if you are still having issues so we can help.
Barrowman
Message 33 of 43
No, I refer you back to my original post. It's when I first turn my laptop on it comes up with the message and I then have to wait for it to re-boot itself then the internet works - the links in mail still wont work either...
Barrowman
Message 34 of 43
Thank you for confirming with feedback @Barrowman as I now assume that it's the links you are trying to access that are giving you issues when accessing since the internet works fine. Correct?
Barrowman
Message 35 of 43
No I just hit the "Cancel" button on the flag and the internet works fine..
Barrowman
Message 36 of 43
This is when you are trying to connect to your internet? Correct?
Barrowman
Message 37 of 43
Deleteing History made no difference. I just checked my phone and it says the following.
Password Incorrect
Enter the password for the iMap account
"My Mail" account
If this means anything,
Barrowman
Message 38 of 43
I understand and I really appreciate for you giving out a helping hand on your end with this.
@Barrowman, how's your browsing history? I will kindly ask for you to try clearing your browser history, access the site once more and re-try accessing the link that's giving you issues.
Kindly confirm with feedback once done.
Barrowman
Message 39 of 43
Hi, Yes KidsSafe is turned off..... That was hard work trying to find that...🙂
Barrowman
Message 40 of 43
Thank you for this. Have you checked on your homesafe settings if your kids safe is turned off?
