on 22-08-2023 07:29 PM
Hi All
Since upgrading to FTTP and plugging in my BT Advanced Z twin phone into a brand new Wifi Hub2 phone port with a filter, my phone registers a missed call approx every 30minutes throughout the day!! It doesnt ring but it lights up the phone.
I have seen Virgin had this issue and rolled out a fix, and another person in this forum has same issue also!.
Is talktalk aware of this? and any help will be appreciated.
See pictures for the message it shows on my landline phone and the images of the phone itself
on 13-03-2024 07:05 AM
Good morning,
Just checking back in to see if the voice issue has now been resolved for you?
on 12-03-2024 07:38 AM
Hi again,
The fix has now been applied. Please could you retest and let us know if this is now working ok for you.
Michelle 🙂
on 12-03-2024 06:53 AM
I'm sorry this hear this. I've asked for the fix to be applied and I will post back to confirm as soon as this has been completed.
on 11-03-2024 09:00 PM
I'll re-escalate this for you, @Shipton47.
on 11-03-2024 07:29 PM
My line had to be reset due to some issue. I am now having the same problem as before. Missed calls are happening every half hour. Please could the fix you did before be applied again?
David
on 30-08-2023 12:44 PM
Hey,
Really glad to hear this. Please let us know if you need any further assistance with anything 🙂
on 30-08-2023 12:39 PM
Hi Michelle
I can confirm that it has been 24 hours and we have had no missed calls.
Thanks a lot of sorting this out.
on 30-08-2023 06:43 AM
Thank you and we will check back in with you in 24hrs to see if this is still working ok. It wasn't a firmware upgrade, our team made a setting change.
on 29-08-2023 02:16 PM
Hi Michelle
It would do it almost immediately. Thanks for this I will monitor.
Did you have to upgrade the firmware on my router ?
on 29-08-2023 12:51 PM
Thanks for the update. Would it normally have re-occurred by now? Would it be possible to continue to monitor this over the next 24hrs to see if this has been fully resolved?
on 29-08-2023 12:48 PM
Hi Michelle
I can confirm since 10.45 we haven't had any missed calls register on the phone.
Do you want us to try anything else?
on 29-08-2023 11:02 AM
Would you mind retesting and confirming if this is now resolved please?
on 29-08-2023 07:58 AM
We're still awaiting an update back on this but I have chased for an update on this now.
on 24-08-2023 09:05 AM
This isn’t an FTTP issue it’s a HUB2 router issue and requires a firmware fix. I believe that BT phones are more susceptible to this issue. It’s the router firmware developers that need to be made aware of the issue.
on 24-08-2023 07:24 AM
I've reached out to one of our FTTP engineers for more info and advice.
on 23-08-2023 06:45 PM
Its ridiculous isnt it, how can talktalk roll this out when its not been fully tested! If Virgin can do a fix, surely Talktalk can sort it.
on 23-08-2023 06:44 PM
Hi Karl
I have done that as you said and its made no difference. As soon as i plugged in it, it resumed with the missed calls.
I didnt have this issue before being upgraded, so what is TalkTalk going to do? It is a nightmare trying to sift through all the missed calls to see the genuine ones.
23-08-2023 08:37 AM - edited 23-08-2023 08:38 AM
I think no ring calls are not that the phone doesn't ring on a legitimate call but the telephone registers a call at regular intervals but the phone does not ring.
This appears to be a common fault when using Non VOIP phones on a VOIP circuit i.e phones plugged in to routers or adapter. I believe it is something to do with the voltage regulation/stability at the phone connection to the router and something is triggering a regular phone interruption but not a phone call hence no ringing tone. It also appears that certain models of phone are more susceptible to this issue.
This has been reported before and also been an issue for Virgin Media customers with a similar setup when plugging non VOIP phones in to their routers. Virgin Media issued a router firmware upgrade which appears to have fixed the issue. TalkTalk need to do the same.
on 23-08-2023 08:01 AM
Can you power down all equipment for 30 minutes, including the router and ONT. This will clear the current session. Restart all the equipment, then give it 10 minutes to settle, and make a test call to the landline.
Does it then ring when called ?
