replacement router
Angelat123
Message 10 of 10
My replacement router died and I got in touch with a live agent who promised a replacement, however, he was unable to advise when the replacement will be delivered. How do I track the delivery of a replacement router?
9 REPLIES 9
Message 1 of 10
I'm glad to hear this and thanks for the update 🙂
Message 2 of 10
Glad to see that. To be fair to the live agent it seems that they did place the order for you, but it took some time to work through to the delivery stage.
Angelat123
Message 3 of 10
Thank you all very much for your help. I've just received an email from yodel advising that an order has been placed and the router will be delivered in 48hrs. Not sure what happened with the live agent who was supposed to place the order, but in any event I am very grateful for the prompt and helpful responses in this chat. I need wifi for work and my children need for school so your help is greatly appreciated🙏🙏🙏
Message 4 of 10
It looks like you have now, the support team should pick this up again tomorrow.
Angelat123
Message 5 of 10
Hi Debbie I think I updated my profile name and number but this platform is very confusing and not user friendly at all.
Message 6 of 10
Hi @Angelat123 did you update your profile as @Debbie-TalkTalk requested? She will then be able to give you a quick answer and check everything is going correctly. As I said earlier 48 hours but if someone pressed the wrong button, needs to be checked for you.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
Message 7 of 10
Hi Divsec, I spoke with the agent the day before yesterday. My issue is that I have no idea when to expect this and need it for work and my son needs for school. Hotspotting can only go so far
Message 8 of 10
Hi @Angelat123
Please can you add your name and TalkTalk landline number to your Community Profile, I can then take a look at this for you.
Divsec
Message 9 of 10
Hi @Angelat123 it's usually within 48 hours so when did you talk to the live agent?
