Home Phone
18 Month Half Price Unlimited UK Calls Boost is ending...
KCFunshineBand
Message 8 of 8
If this cannot be extended/renewed, I can't afford the extra £8 a month...any suggestions would be gratefully received! Thanks in advance..x
7 REPLIES 7
Message 1 of 8
Hi @KCFunshineBand
I can help with this I first need to confirm some security questions
I have sent you a PM on the community
Message 2 of 8
Hi Anne... Not yet! I've tried several times to get through but no luck so far. Thank you for asking.
Message 3 of 8
Message 4 of 8
Thanks for taking time out to reply to me; having that number really helps!x
Message 5 of 8
Thanks so much for responding; I'm like a fish out of water with stuff like this and your advice is much appreciated..!x
Gliwmaeden2
Message 6 of 8
If you can't get a good deal, but already have a good calling package on a mobile, @KCFunshineBand, it's worth just not adding the boost, but use your mobile allowance/free calls allowance if you have a good tariff.
Voice quality is sometimes impaired, but people can still ring in on your landline anyway.
There are good mobile tariffs out there @£5 for inclusive texts and calls, and 1 or 2 GB data to fall back on.
Message 7 of 8
If you wish to see what deals are available, you would be best to speak to the Loyalty Team as they hold the best deals if there is one they can offer.
Try phoning 0345 172 0088
Opening Hours can be found here - https://community.talktalk.co.uk/t5/Articles/How-to-contact-TalkTalk-Broadband/ta-p/2230529#
