Home Phone
Caller display stopped working
37ttcom
Message 23 of 23
  • My caller display stopped working weeks ago.  All we get is "Incoming call".
  • This is a feature which we require and find very useful. It had been working without any problem with our existing equipment for a number of years.
  • No changes were made to my systems, equipment or devices.
  • Have tried to resolve this many tomes by switching off the add-on,  leaving it off for several hours and then switching on again.  Has not worked.
  • Have tried chatting to the Tech Team, but got nowhere at all after more than an hour and gave up.
  • Have also tried tried connection tests several times from My Account web site.  Says there is a problem and initiates a line test, which either drops out and says "encountered an error try later" or results in nothing at all or text message suggesting I chat to tech help.  Never any feedback identifying the problem.
  • I have had connection problems before, which I said at the outset had to be a line issue outside of my property or at the exchange.  After hours on the phone, all sorts of tests, two visits from the BT Engineer and one visit from TalkTalk Engineer proved to be a problem at the exchange.  During the course of his, the BT Engineer was tearing his hair out trying to speak to someone at TalkTalk to get them to reset their equipment, and he had a special direct line number!
  • I see that other users have experienced similar issues with Caller Display and, reading the posts, it has often taking them weeks or months to resolve, usually by TalkTalk technicians.
  • It appears that TalkTalk have a systems issue with this and I really think it is time that they got a grip on it and stop always assuming that the problem must be with the user.
  • Perhaps someone there will read this carefully and take appropriate action to reactivate this service for me, although I say that more in hope than expectation.
  • If anyone else has any suggestions as the how to get this resolved, I should be glad to her from them.
22 REPLIES 22
Message 1 of 23
@mgreenwood487572
You will see that this an old thread. Please start your own topic if you want help.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don’t worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - TalkTalk Help & Support
mgreenwood487572
Message 2 of 23
I'm having the exact same problem and talking to Talk Talk has proved to be a waste of time. Their Tech support is rubbish.
Gave up trying to solve the problen in the end.
Unhappybunny2
Message 3 of 23
Hi 37ttcom
I’ve been in exactly the same boat as you for nearly two years.
Unhappy Bunny
Message 4 of 23
37ttcom
Message 5 of 23
Noted.  Thank you.
Message 6 of 23
OK thanks, I'll pass this over to our network team and ask them to take a look. I'll let you know when I receive and update or they may contact you directly
37ttcom
Message 7 of 23
Yes Caller Display showing on My Account.
In anticipation of your question, still not working.
Message 8 of 23
Apologies, I didn't intend to switch callsafe off, I'm not really sure how I did it to be honest, I triple checked that it was caller display that I was switching off so not sure how it's happened.
Just to confirm, is caller display now showing as on in your My Account?
37ttcom
Message 9 of 23
No, still not working.
Whilst I appreciate your assistance, it would have been a good idea if you have told me before you switched Callsafe off so that I could make a note of the Blocked and Approved numbers.  I have no record of previously Blocked numbers and now have to try and remember all the Approved numbers and re-enter them which is a pain and very time consuming.
Be aware that whenever I have experienced problems in the past, the fault has always eventually been located in the exchange.  Also, in case it is relevant, I am still on copper here as fibre is not available.
Message 10 of 23
Hi 37ttcom,
Callsafe should be back on now. Could you just check my account and tell me if Caller Display is showing enabled now
37ttcom
Message 11 of 23
By the way, Caller Display still not working.
37ttcom
Message 12 of 23
I have received your latest message and then, immediately afterward, another e-mail to advise me that my Call Safe had been switched off.  I presume that was some thing that you were doing?
Can I switch Call Safe back on?  Will this mean that I will now have lost all my barred and permitted numbers and will have to re-enter them all?
Message 13 of 23
OK thanks, could you just leave it with me, I'm just going to try something else
37ttcom
Message 14 of 23
Thanks for your recent messages.  Unfortunately, nothing has changed.
Message 15 of 23
I've removed it, I'll re-add it in 30 minutes
Message 16 of 23
OK thanks. I'll try removing it and re-adding it
37ttcom
Message 17 of 23
You will see from my original post that I have tried this before, in fact I have lost track of how many times.  However, have tried it again today, but no change.
Message 18 of 23
OK thanks. Have you tried removing it and re-adding it in My Account, if not then can you give this a try
37ttcom
Message 19 of 23
No change I'm afraid.  Still shows "Incoming call".
Message 20 of 23
Thanks. I've made a change, can you please retest and let me know if caller display is now working
