Home Phone
Can't access voice messages on talktalk landline
GaynorO
Message 24 of 24
Can't access voice messages on talktalk landline. Was working fine then stopped for no apparent reason.  Can anyone help fix this. Thanks Gaynor
23 REPLIES 23
Message 1 of 24
This is a very old thread. The only Voicemail service which TalkTalk currently offer is a paid for Boost. If you want further advice from the support team, please start your own topic.
MaryD1
Visitor
Message 2 of 24
Voicemail not working on landline as it had been in the past
Message 3 of 24
Ok thanks for confirming. If this does happen again then please let us know and we can ask our Faults Team to take a look.
Message 4 of 24
Not sure exactly, I would say about every 4 months. Last time was in June and I think this is the 3rd time its happened.
Gaynor
Message 5 of 24
Thanks for confirming. How often does this keep happening?
Message 6 of 24
Hi Michelle
Thanks for your help.
Just switched the ONT etc off for the 30 minutes and it seems to have done the trick.  Hopefully it won't stop working again. Do you have any idea why this keeps happening?
Message 7 of 24
I'm sorry to hear this. Just to confirm, have you tried powering down the ONT and digital voice adapter for a full 30 minutes and then retested this again?
GaynorO
Message 8 of 24
I can't access my landline voicemail again. It keeps randomly not working when I haven't changed anything. Been not working for a few weeks now. Message box is full but can't access any of the messages. Also can't make phone calls but can receive calls. Makes the dialing tones but then nothing happens.
Message 9 of 24
We wouldn't recommend switching the ONT off too many times, however just for testing switching the ONT off once should be fine. Please let us know how you get on.
Message 10 of 24
Thanks for your advice. My concern is that when the ONT box etc was installed I was told by the openreach engineer to never switch the ONT box off.
Message 11 of 24
OK thanks Gaynor, when you get chance could you power down the ONT, eero and Grandstream DVA, leave them off for at least 30 minutes then switch back on and retest
Message 12 of 24
Hi Chris
In that case yes I do have all three but I have not tried switching off the eero and grandstream yet as my daughter is using the inernet for her exam coursework which has to be handed in tomorrow so don't want to cause any disruption.
Gaynor
Message 13 of 24
The ONT is the box on the wall
Message 14 of 24
I do have the grandstream and the eero but not sure what you mean by the ONT.
Gaynor
Message 15 of 24
Just to confirm, you currently have the ONT, eero and the grandstream digital voice adapter? Have you tried powering down the digital voice adapter and the eero for a full 30 minutes and then tried connecting this again?
GaynorO
Message 16 of 24
Just checked and the phone is connected to the grandstream box
Gaynor
Message 17 of 24
OK thanks, does you telephone connect directly to the router?
Message 18 of 24
Not sure. It was all updated by talktalk to fibre about a year ago,  so I presume talktalk did whatever they would normally do to keep everything working.
Gaynor
Message 19 of 24
OK thanks, are you using the Grandstream digital voice adapter?
Message 20 of 24
Hi Chris
The phone dials the 1571 numbers but after that nothing happens.
Gaynor
