on 08-08-2024 08:27 PM
on FTTP Fibre 65 with voice direct.
Suffered from Ghost calls every half hour or so last December which was fixed by the lovely Community team.
All was well until recently when I ha£ to replace my router as the original one became faulty.
Since replacing the router (WiFi Hub 2) the ghost calls are back, much the same as before.
Any chance of working your magic again?
Many thanks
on 12-08-2024 06:50 AM
on 10-08-2024 08:30 PM
Hi Karl. Thanks so much for your help with this. I can confirm that the calls appear to have stopped so I'm really grateful to you.
The Community triumphs again!
on 09-08-2024 08:19 AM
Hi @chrishtie
I've applied the Fix to your router.
on 09-08-2024 06:25 AM
Hi @chrishtie sorry to hear that, your post has been escalated so help is on the way.
