Home Phone
Landline no dial tone
Jam_bo
Message 24 of 24
My landline is not working.   Just have background noise when I pick up the receiver.
Please investigate.
23 REPLIES 23
Message 1 of 24
Hi @Jam_bo
I'm so glad to hear that the line is working again.
I've sent you a Private Message with a link to a short survey for the Community.
Jam_bo
Message 2 of 24
Hi Kari,
I've just checked the line and it is back up and running.
Many thanks for your help.
Kind regards
Jam_bo
PS: Please can you tell me how I can give feedback on this thread in confidence?
Message 3 of 24
No updates as yet from Openreach, but the fault report is in progress with them.
We will check back in with you after the weekend to see how things are going.
Message 4 of 24
Morning @Jam_bo
The fault has been assigned to a line engineer this morning, we should hopefully have further updates later this afternoon.
Message 5 of 24
@Jam_bo  I am pleased to see that the support team are on the case for you. I can also see that the indictor against your username is now there, so for my own peace of mind can you advise whether you managed to make a further change after our earlier, lengthy discourse?
Message 6 of 24
Hi @Jam_bo
The line test is detecting a potential line fault so I have passed this straight over to Openreach to be investigated by a line engineer.
I will continue to monitor for updates and I will post back on this thread.
Message 7 of 24
Apologies, it may be that the indicator is just not showing for some reason. Rest assured that the support team will pick up your issue and deal with it.
Jam_bo
Message 8 of 24
My landline hasn't changed.
I confirmed that my landline was in my profile in the 3rd, 5th, 7th and 9th posts above, and again in the 15th.
This is not OK.
Message 9 of 24
OK, as I said, don't worry about it. If you are talking "many years ago" perhaps something has changed. Either way, it is a distraction from the case in point.
Jam_bo
Message 10 of 24
That was already there when I first looked at the community settings/profile and I have not changed it.  I added it many years ago.  That is the only useful data field for support in the whole profile.  The rest is irrelevant.  What possible use is my biography for example?
Message 11 of 24
OK, try your TalkTalk phone number?
Jam_bo
Message 12 of 24
I have just used the wizard for updating my profile and went through the entire wizard and saved it.  This doesn't seem to have made any difference.
Jam_bo
Message 13 of 24
Test
Jam_bo
Message 14 of 24
I fully understand that I have a talktalk account and a separate community account and that their settings are separate.
When you first asked me to update my talktalk community account I copied the account number from my talktalk account into the Customer ID field on my talktalk community account and saved my community profile.
I searched for other fields that might help but alas I found none, hence my questioning to you.
If you want me to add more information please can you be specific about the additional fields that I need to fill in. ie tell me the exact name of the data field that I must fill in.
Message 15 of 24
I am not asking you to add any information to your TalkTalk My Account, but to your profile on the community to which I posted a direct link, twice. Can you not the see the necessary details to fill in here? Make sure you click the Save changes button at the bottom of the page. I know it may seem repetitious, but it will help the support team. The journey in may a bit a wee bit different to what you knew before. Don't worry, you have still come to the right place. The support team should pick this up tomorrow.
Jam_bo
Message 16 of 24
Although I have used the community before, to access it this time I had to log in to my talktalk account and associate it before could re-access the community so I assumed perhaps wrongly that talktalk had connected my community account which is accessed through the same email with my talktalk account.
I've been back into the settings many times now since you first asked and I can't see what more I can do in relation to my talktalk account.   My landline was there already.  I added my account number into the Customer ID field.    I added my mobile but it didn't make any difference..
Previously I have been able to get support through the community.  If I now need to do something else to fix my landline problem rather than posting here please let me know.
Message 17 of 24
OK, there is an indicator under your avatar and username which shows when your profile is complete, like the TalkTalk one against mine. Yours isn't there. I'll leave this with the support team now.
Jam_bo
Message 18 of 24
My landline is there along with my talktalk account number.  What additional information do you need?
Message 19 of 24
You need to put the details in the link I posted earlier, repeated here for ease, the account association doesn't seem to work in all cases.
Jam_bo
Message 20 of 24
My landline is in the account.  I have added my talktalk account number.  My community account is associated with my talktalk account. What other account details do you need?
