Home Phone
Landline - no dialtone + incoming calls going straight to voicemail
jlyons1978
Chat Champion
Message 95 of 95
Over the weekend, I have lost the ability to receive or make calls on my landline. Internet appears to be unaffected, so I have done the usual tests - check on the test socket with a wired handset.
Fault was checked on the website, and they confirm that there is a fault, and that I need to speak with a Team member. The blue button does not link to anything though, with no chat window coming up or details of a phone number to contact.
Please can someone help to resolve this?
94 REPLIES 94
Message 81 of 95
Have you tested your phone in the test socket before contacting us?
Phili
Message 82 of 95
Yes
Message 83 of 95
Please confirm that your telephone is correctly connected to your master socket?
Yes - Telephone connected correctly
No - Not checked
Phili
Philile-TT
Message 84 of 95
A line test is currently underway. This checks the equipment used to provide the broadband service to your home - including the exchange, cabinet and line equipment.
This can take up to 6 minutes to complete. I'll let you know if this test finds a fault, otherwise I'll continue with further checks.
Phili
Message 85 of 95
No for all
Message 86 of 95
Do you have any active monitoring for life threatening health reasons which is solely dependant upon your TalkTalk Broadband or Telephone line?
For example a care alarm, lifeline, health pendant or fall detector.
Phili
Message 87 of 95
I'm home now to do whatever tests are necessary.
Message 88 of 95
We will be here till 18:00pm please write back when you are at home.
Phili
Message 89 of 95
I expect to be home late afternoon (16:30 onwards) or should be in all day tomorrow.
Message 90 of 95
For accurate checks you would need to be in the property just in case you have check somethings. When are you going to be home?
Phili
Message 91 of 95
Sorry, currently at work so no immediate access. There should be no issue if line reset required though.
Message 92 of 95
I will assist you with this, are you currently at home where the TalkTalk services are installed?
Phili
Message 93 of 95
I have not been able to speak to anyone, either on chat (no link on page to a chat window) or over phone as no alternate contact details are provided on the fault page.
Any help would be greatly appreciated.
Philile-TT
Message 94 of 95
Hi there @jlyons1978 have you spoken to someone as yet?
Phili
