on 29-09-2025 04:29 PM
Over the weekend, I have lost the ability to receive or make calls on my landline. Internet appears to be unaffected, so I have done the usual tests - check on the test socket with a wired handset.
Fault was checked on the website, and they confirm that there is a fault, and that I need to speak with a Team member. The blue button does not link to anything though, with no chat window coming up or details of a phone number to contact.
Please can someone help to resolve this?
on 01-10-2025 08:16 AM
Have you tested your phone in the test socket before contacting us?
on 30-09-2025 05:45 PM
Yes
on 30-09-2025 05:40 PM
Please confirm that your telephone is correctly connected to your master socket?
Yes - Telephone connected correctly
No - Not checked
on 30-09-2025 05:05 PM
A line test is currently underway. This checks the equipment used to provide the broadband service to your home - including the exchange, cabinet and line equipment.
This can take up to 6 minutes to complete. I'll let you know if this test finds a fault, otherwise I'll continue with further checks.
on 30-09-2025 04:59 PM
No for all
on 30-09-2025 04:55 PM
Do you have any active monitoring for life threatening health reasons which is solely dependant upon your TalkTalk Broadband or Telephone line?
For example a care alarm, lifeline, health pendant or fall detector.
on 30-09-2025 04:47 PM
I'm home now to do whatever tests are necessary.
on 30-09-2025 11:40 AM
We will be here till 18:00pm please write back when you are at home.
on 30-09-2025 11:34 AM
I expect to be home late afternoon (16:30 onwards) or should be in all day tomorrow.
on 30-09-2025 11:25 AM
For accurate checks you would need to be in the property just in case you have check somethings. When are you going to be home?
on 30-09-2025 11:19 AM
Sorry, currently at work so no immediate access. There should be no issue if line reset required though.
on 30-09-2025 11:12 AM
I will assist you with this, are you currently at home where the TalkTalk services are installed?
on 30-09-2025 11:03 AM
I have not been able to speak to anyone, either on chat (no link on page to a chat window) or over phone as no alternate contact details are provided on the fault page.
Any help would be greatly appreciated.
on 30-09-2025 09:32 AM
Hi there @jlyons1978 have you spoken to someone as yet?
