on 19-10-2023 10:26 AM
After running a line test 2 days ago to ensure everything is O.K. a fault was supposedly found (Re: REP 13515790). What the fault is I have no idea. Later I received a text stating 'we have completed the test on your line. If you're still experiencing issues , we will need to investigate this further.' When I logged onto my account the fault was showing as an open case. I then contacted live chat and was asked what the problem was. I do not know what the problem is, as it was found during the line test. I have logged on this morning and found the fault is still an open case, is there a fault or not.
Answered! Go to Solution.
on 23-10-2023 12:54 PM
Hi Ganger
Thank you 🙂
The line test is still clear - No faults detected.
I can try the test one more time with the phone re connected. Would you like me to test it again with the phone?
on 23-10-2023 12:50 PM
Hi Debbie
Only the filter and router are connected to the test socket.
on 23-10-2023 11:38 AM
Hi Ganger
Thank you 🙂
The line test is now clear. Could you now connect just the filter and router (leave phone removed) whilst I do one more test?
I'm just trying to see what is causing the loop fault. If the fault is back with the router connected then I can send a replacement router for testing to see if this helps.
on 23-10-2023 11:33 AM
Hi Debbie
Just the phone, filter and router at the test socket. I am now disconnecting from the test socket.
on 23-10-2023 10:16 AM
Hi Ganger
Thank you. I've completed another line test and the same fault has been detected.
Do you just have the phone, filter and router at the test socket?
Would it be ok to remove everything from the test socket for 30 minutes so I can run a line test with everything removed?
on 23-10-2023 09:59 AM
Hi Debbie.
I am connecting to the test socket now.
on 20-10-2023 12:40 PM
Hi Ganger
I've completed 2 different line tests and one of these tests (landline test) has detected a loop fault. This fault is often caused by internal wiring or equipment connected to the line.
Would it be possible to connect the phone, router and filter at the test socket so I can run another line test in this set up?
20-10-2023 12:09 PM - edited 20-10-2023 12:17 PM
Thank you for taking this up.
No, I wasn't having any problems. Which is why I assumed the problem is out of my control.
I have just run the line test again and it shows again 'we think there is an issue with your line'.
on 19-10-2023 10:53 AM
Hi Ganger,
Could I just ask, are you actually experiencing any problems with your service?
on 19-10-2023 10:49 AM
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
