Home Phone
One-way only calls on full fibre
JuneN
Message 35 of 35
Ever since switching to full fibre (in the hope that it might resolve the regular line distortion during calls) I now find that 50% of the time, when someone calls me, they can hear me clearly but all I hear is silence.  If I call them straight back it's usually fine.
Also, frequently when I make a call it just drops before connecting.
I've power cycled the Hub 2 router and reset it.  Have given up trying to speak to the Talktalk call centre.  After spending ages going through security and then waiting around, they decide that I need to speak to the Full Fibre team.  I get passed over to them, same delays then they decide that as it's a "phone issue" I need to speak to the main support team, and round we go.
Any ideas how to progress this?
June
34 REPLIES 34
Message 1 of 35
Hi Geoff,
I'm glad to hear this and thanks for confirming 🙂
Message 2 of 35
Morning Michelle.  Restarted it again and looks like it is working again now, thank you.
Geoff
Message 3 of 35
Good morning,
I'm sorry for the delay. This should now be resolved. Have you rebooted your eero and digital voice adapter?
Message 4 of 35
I don't know, I am just a customer like yourself. The support team will be back online tomorrow to advise further.
Message 5 of 35
Hi - is this resolved yet?  Still having the same issue and nothing showing on the service status page.
Message 7 of 35
/Hi Michelle
Unfortunately voice is playing up again; incoming, the caller just hears the ring tone, when answered there's just silence.  Outgoing calls she gets the engaged tone.
We've power cycled the Grandstream and remote restarted/firmware updated the eero, internet appears fine.
Don't seem to be able to run a connection test as it says we've still got the copper line as well as fibre.
Any ideas?  Thanks - Geoff
Message 8 of 35
Morning June,
I'm really glad to hear this 🙂
Message 9 of 35
Morning @Anonymous - so far, so good; no dropped calls since moving over to the eero.
Thanks again for your help.
June.
Message 10 of 35
Morning @JuneN
Just checking back in to see how the voice service has been since your last post?
Message 11 of 35
That's great Geoff, thanks for letting me know
Message 12 of 35
Hi Chris
All sees to be working fine, thank you.
We'll give it a while to see if that has resolved the phone call issue.
Kind regards
Geoff
Message 13 of 35
OK, I've changed the profile, it should take effect in the next few minutes
Message 14 of 35
Message 15 of 35
Hi Chris/Michelle - ok, cables have been swapped so now:
Fibre wallbox ==> eero port 1
eero port 2 ==> grandstream DVA ==> telephone handset
Please go ahead with the config change to enable the eero.
Kind regards
Geoff.
Message 16 of 35
Message 17 of 35
Hi Chris - no, I'm liaising with you on Mum's (June) behalf so I'm miles away on a separate connection.
Thanks - Geoff.
Message 18 of 35
Hi Geoff,
Could I just ask, are you posting from a device connected to your TalkTalk landline?
Message 19 of 35
Hi Chris/Michelle
Could you please make the config change for the eero to work tomorrow (Thurs 18th) please?  Ideally around 12.30 as I'll have someone available to swap the cabling around and connect the eero in place of the hub.
Please update the ticket when done.
Thanks - Geoff.
Message 20 of 35
OK Geoff, no problem 🙂
