Home Phone
Phone over voip
Trendy2000
Message 43 of 43
My land line phone is not working.
It seems like it is going to work, makes a dial tone then the peeps as i dial a number.
the phone is answered but after a couple of seconds it just cuts out, and the has a continuous bleep.
if I try to ring straight back again it has an engaged tone.
i cant receive calls?
any body any idea of the problem?
i have a Grandstream VOIP box.
all three lights are on.
tried unplugging and then switching back on.
42 REPLIES 42
Message 21 of 43
Hi Gleha
Apologies for this.
The team are investigating this at the moment as a priority.
Gleha
Message 22 of 43
Same problem.
apparently a problem with talk talk
they said this morning it had been resolved and to switch off eero and grandstream and use reset pin on grandstream
did not work
hope they can get their act together soon
Message 23 of 43
Our Network/Incidents Team are looking at this now and I will post back as soon as I have further information.
Message 24 of 43
Thank you for your help, I hope they can resolve the issue quickly.
Message 25 of 43
Ok. I have also just tried the above.switched off eero and grandstream and used reset button on grandstream and exact problems remain - no in coming calls and outgoing cuts off after a couple of seconds
Message 26 of 43
Thanks for confirming. I've escalated this straight over to our Fault Escalation Team now and will post back as soon as I receive an update. It's possible that the team may also try and contact you directly.
Message 27 of 43
No sadly it isn’t, have tried that procedure 3 times and still no luck.
sometimes I can make a call for around 7 seconds, then it drops out.
if I try calling again straight away I just get an engaged tone.
i can’t receive calls either
Message 28 of 43
Hi Trendy2000
Is it still not working after the power down of the eero and the factory reset of the grandstream?
Message 29 of 43
Reassuring to know it’s not just me, but sorry you are having the same problem!
Message 30 of 43
I have done that Michelle
Message 31 of 43
Hi Tulips99,
If this is still happening after the power down of the eero and the factory reset of the grandstream, then please can you create your own topic and we can look into this further for you.
Message 32 of 43
Hi Trendy2000,
  • Name
  • Telephone number
  • Alternative contact number
Tulips99
Message 33 of 43
This is exactly my problem. I am about to reset eero and grandstream but not hopeful of a solution now
Message 34 of 43
Tried this Michele, still no joy.
if I make a call it works for just 7 seconds then fails every time
can not receive calls
Message 35 of 43
I'm really sorry for the confusion, could you try resetting the DVA instead please.
Message 36 of 43
Just tried powering down both the Grandstream and the eero
pushed the factory reset button on the Grandstream
no luck, still having problems.
i can make a phone call for 7 seconds then it drops out, can’t receive calls
Message 37 of 43
Sorry for the confusion, it's the reset of the DVA.
Message 38 of 43
No still not working here
Message 39 of 43
Hi again,
Just to add,
We’re aware that some Full Fibre Digital Voice (VoIP) customers are currently unable to make and receive  calls.
Latest update: 08:10am 13th December 2023
Service has been restored, we recommend if you're still being affected, to power down both the eero router and the Grandstream digital voice adapter and use the factory reset pin, this will clear the issue.
Message 40 of 43
Good morning,
Apologies. There was a VOIP incident yesterday which should now be resolved. Is your voip/voice service now working?
