Home Phone
home phone
andrew66
Chat Champion
Message 26 of 26
i have an intermittent problem with the phone, i tried calling TT but cant get to speak to a human, i tried live chat but they just read a script that the problem doesnt fall into, i have asked them to phone me to discuss it but they refuse saying they cant phone, where do i go from here ? or do i just go to another provider ?
25 REPLIES 25
Message 1 of 26
Hi Andrew
If there's a fault on the line then there will be no charge. You've confirmed that you've tested with 2 different telephones at the test socket and you still have the same issue so it does look as though it's a line fault.
Message 2 of 26
the phone is still faulty but i cant afford to pay you to visit so i am at the mercy of TT who have turned out to be a waste of space.
Message 3 of 26
Hi andrew66,
If you need any further assistance just let us know
Message 4 of 26
thank you for your kind offer, i am a stroke survivor and get mentally tired quickly, i can sort it but just takes me a bit of time to think. im trying to sort a sim only contract at the moment so i have a reliable phone and thats hard work.
Message 5 of 26
If I can help at all, just let me know.
Message 6 of 26
yes i know, i had to set up the 5ghz ssid to a different name as you will know if the 2.4 and 5 have the same ssid it will cause conflicts with some devices, i still have port forwarding to set up but need to work out what ports i forwarded last time.
Message 7 of 26
Message 8 of 26
Hi @andrew66 @Chris-TalkTalk
Just be aware, that with this bug, the UI looks perfectly normal, but there will be no WiFi signal sent from one band or the other. If no devices are still able to connect to the 5GHz band, I would do the factory reset. The easiest way is to press the recessed switch near the power button on the back of the router for about 10 seconds while it is turned on.
Message 9 of 26
OK thanks. Your router has the latest firmware, the firmware is automatically updated. Both the 2.4GHz and 5GHz bands appear to be enabled.
Message 10 of 26
the one ending 1
Message 11 of 26
Just to confirm, you have two telephone number in your community profile, is this regarding the line ending in '1' or '5'?
Message 12 of 26
it happened 3 days ago by the looks of it when i reported problems with phone to TT and they started talking about internet speed and not the phone problem, to be honest TT have had me in tears over this problem by not listening to the symptoms which makes it obvious its an exchage fault.
Message 13 of 26
Hi @andrew66
Have you by any chance disabled & re-enabled any of the WiFi bands in the router? If you have, there is a bug in the current firmware that means that they will never work properly again. The only workaround at the moment is to do a factory default on the router's configuration & it will be fine after that. I did report this to the developers.
Message 14 of 26
all my devices that used the 5ghz stopped working, it took me a while to realise that the router had been reset with new firmware and the 5ghz ssid had been changed back to its default. i have a feeling TT think im on voip but im actually on pots for the phone.
Message 15 of 26
Sorry what do you mean about changing the settings on your router?
Message 16 of 26
i cant afford it although i just tried to dial out at 12.59 pm and the call failed but worked the second time and why have TT changed settings on my router when its the phone thats the problem.
Message 17 of 26
I can see that Gliwmaeden2 has pointed you in the right direction. Please let me know if you'd like to go ahead with the engineer visit
Message 18 of 26
@andrew66,
https://community.talktalk.co.uk/t5/Articles/Engineer-charges/ta-p/2207291
Message 19 of 26
as its an intermittent fault and may not show up when the engineer visits can you tell me how much it will cost so i can save up for it.
Message 20 of 26
OK thanks. To investigate further we'll need to arrange an engineer visit, if you'd like us to do this please let us know and we'll confirm some details with you
