on 30-12-2024 11:05 AM
My land line has stopped working. How do i report it?
on 30-12-2024 11:38 AM
A line test is showing a loop fault, thats usually 2 wires close or touching, in or near your property.
Can yo unplug all from the phone socket and test your handset directly at the master socket, or 'Test Socket' if you have one, and try an alternative handset if you have one. This will rule out an issue with the handset itself.
