Home Phone
landline rings every 30mins
lucy24
Message 53 of 53
Hi, I had this problem 26th March 2024, after having fibre installed, and Michelle from talktalk support fixed it thanks to Ferguson (community star) telling me it was a known problem.
I have experienced regular drop-offs in router and landline over last 24hours, and contacted talktalk this morning, they did a factory reset of the router which (fingers crossed has fixed the broadband problem) but the ding every 30 mins on the landline is still there, which is annoying at best....please can someone from the support team pick this up and help?
52 REPLIES 52
Message 1 of 53
Do let us know here if you have any further issues.
lucy24
Message 2 of 53
Hey to you Debbie,
package came yesterday, unfortunately not letterbox size but postie secreted it out the front....found it earlier when I arrived back and have just unwrapped it and plugged it all in...the phone is doing a lot of dings, hopefully that will be an initial thing and once it's all solid lights will stop....but there is now a phone line that I can answer to the old folks now.
Thanks once again
Message 3 of 53
Hi @lucy24
Have you received the digital voice adapter?
Message 4 of 53
Hi @lucy24
No problem 🙂
It's on its way, please allow 24-48hrs for this to arrive.
Message 5 of 53
Yes please….thank you Debbie
lucy24
Message 6 of 53
Yes please : )
thank you
Message 7 of 53
Morning @lucy24  🙂
It's small, the box should fit through the letter box. Are you happy for me to order this today?
lucy24
Message 8 of 53
Hey Debbie, many apologies I have only just got back from a very long day at work...the internet was great all weekend...managed to watch the football yesterday and the only problem with that was the scoreline : )
Can I say yes please for the voice adapter, is that small enough to fit through letterbox or is that a knock at the door type piece of kit?
Message 9 of 53
Morning @lucy24
Sorry for the delay.
Has everything been ok over the weekend? I can send the digital voice adapter for you.
lucy24
Message 10 of 53
Hey to you Debbie
I had a text conversation with Jamie on Wednesday afternoon after I asked how problem fixing was going, the outages were then still on-going and within that time, it had been resolved....the issue of area drop-offs and we were up and running again.  It seems to good, I wasn't in yesterday, but everything looks ok and today is running smoothly....so I believe zit is resolved.  My only problem now is marrying the corded phone back to the router, which someone mentioned you guys send a Digital Voice Adapter out, is that the case or do I actually have to start looking into it.
I thank you and Michelle for keeping me updated and investigating from your side : )
Message 11 of 53
Hi @lucy24
I've requested an update and I will post back here as soon as the team come back to me.
Message 12 of 53
Hi @lucy24
No problem. I will post back here as soon as I receive further updates.
lucy24
Message 13 of 53
Thanks Debbie, I can see there has been a voicemail, 24 secs, but when I try to listen to that it's just a blank, so I appreciate firstly, their attempt, but more so, your relay of what's happening
Message 14 of 53
Hi @lucy24
My colleague has advised that they have tried to make contact and have left you a voicemail.
This is the latest update on this fault:
Good Afternoon, We have identified a wider outage within the area which is affecting multiple services seeing intermittency. This outage is part of the wider outage in the area. We have raised a task with our network engineering team to investigate/resolve this outage. As soon as we receive any updates/ETA'S from our engineering team, we will update you accordingly.
lucy24
Message 15 of 53
Message 16 of 53
Hi @lucy24
Apologies for this.
I will contact the team now to find out what is happening and I will post back here as soon as I have more information.
lucy24
Message 17 of 53
Hi to you Debbie,
there was a phone call due yesterday to update me on problem, but I didn't get one.  There have still been outages, the last one being this morning between 2am and 5:30am...so not sure if anyone has actually identified the problem and it's being addressed or not.  My neighbours also are still struggling to maintain connection.
Message 18 of 53
Hi lucy24
Has my colleague been in contact with you since your last post?
lucy24
Message 19 of 53
you star : )
Anonymous User
Message 20 of 53
Hi lucy,
Apologies, if they come back to me with any additional updates then I'll post an update here for you.
Anonymous User
