Help needed as I have deleted supersafe portal
27 REPLIES 27
Peter45
My Talktalk account includes supersafe boost for multiple devices.I looked in the supersafe portal earlier today and found that only 1device was protected .I have chatted online to Talktalk for most of the day only to be told that I should be here so that F secure can help me set up the portal again.I deleted the supersafe app on my iPad,the one device that was protected as I thought it was faulty.The supersafe app on 2other devices that should been protected is showing that subscription has expired.I do not have the original e mail sent by F secure to activate the supersafe app.Can anyone help please?
I'm assuming you have the multi device boost option active in your account, as opposed the free 1 device option.
If so, have you tried logging into your f-secure account without the e-mail.
The logon information should be the same as you use for My Account (if not try the forgotten password link)
I suggest that you release any licence that applies to your devices that are showing as expired and uninstall them. as the system will think you are attempting to install on another device rather than reinstalling. You should be able to install from there.
If you are still having issues then please post back and I'll escalate for an OCE to look into for you.
Peter45
Thank you for your reply fr8ys.Unfortunately,when I log into my supersafe account it is showing that I have only 1licence,even though I should have multiple licences.It does not give me the option to do anything with expired licences.
There seems to be some disconnect between TalkTalk,who tel me I have multiple licences and F Secure which is showing only 1 licence .
Ok, I've escalated for an OCE to look into for you.
OCE_Ady
Hi Peter45, there's a stuck order on your MyAccount. I've requested that it's cleared so that you can readd SSB. I'll post back once I've had confirmation that the issue is cleared.
Peter45
Hello OCE_ADy,
I was wondering if there is an update on my problem please?
OCE_Ady
Hi Peter45, I'm afraid not yet. I've sent another chaser to the team who have to remove this from your account. Chase me again tomorrow please.
OCE_Ady
Don't chase me tomorrow. You can make any change you want now. My colleagues has fixed the problem with a stuck order and it's all sorted for you. Please let me know if we can do anything more for you.
Peter45
Thank you OCE_Ady,
I shall try to add other devices to my SSB.
OCE_Ady
Please let me know how you get on.
Peter45
Hello OCE_Ady,
I have been into my TalkTalk account and the message about making changes to my SSB has gone.I have opted for the 8 device coverage and confirmed when requested.
I have logged into the SSB account which is showing that my subscription (showing as 0/1) is suspended.
I now have no SSB coverage on any device!
OCE_Ady
Sorry about that. I've just been in and reactivated your account. Let me know once you've been able to check. I've also logged in to your SafeAvenue and checked that your device is showing as protected and it looks good. I should have thought that it might be suspended after being out of use for such a long time.
Peter45
Thanks OCE_Ady,
I have logged into my TalkTalk account which is still showing that I have selected the multiple device option.
Having then logged into SSB through my TalkTalk account and via the SSB app,that is showing that I have a licence for one device only and it is protecting my iPad.So,I am back to where I began.
TalkTalk is showing that I should have the licences to protect multiple devices but SSB only give me the option to protect one device......
OCE_Ady
What a massive pain this is being. I've checked on 2 out of 3 systems it's showing 8 licences. But and it's a big but the Fsecure system isn't updated from 1 licence. I've sent it over to get this sorted for you.
Peter45
Thank you ODE_Ady,
I have my fingers crossed!
OCE_Ady
Hopefully, it won't be too much longer until this is properly sorted out.
Peter45
Hello OCE_Ady,
There is no change in my TalkTalk or SSB accounts....is there any progress on my issue please?
OCE_Ady
Hi Peter45, the team believed they'd fixed this. I've advised them that they're not correct and asked for a speedy resolution to this as you've waited quite a while for this to be fixed now.
OCE_Ady
I've just checked and all the systems now match and all show 8 users. Please retest and let me know how you get on.
Peter45
Hello again OCE_ADY
I Have just logged into my TalkTalk account which is still showing the multiple device option.When I log into SSB it is showing that I have a valid subscription for 1device.It will not let me add any devices...
It’s a month since I started this process and I am no further forward!
