4K Box and USB not working
Bob1950
Message 7 of 7
Yes I have this same problem.
Purchased a 512GB USB stick. Formatted it to NTFS then inserted it in to the 4K TV slot and the box stated it had recognised the stick and did i want to initialise it. Selected the button and it seemed to start. After a minute or two I got a message stating the USB could not be initialised.
So I tried again and formatted the stick inserted into the 4K TV box USB slot. Same thing occurred.
I then tried to get help via the Chat Help Bot.
Round in circles until I got an agent. Then after 30 mins I was told it was not in their area but in Community Fibre who could do diagnostics.
What they could be to solve this problem by some diagnostics I just do not know. I was happy with the previous DM372 box . The only real problem was getting ITVx.
Is there a solution. Do you have to purchase a specific USB stick?
6 REPLIES 6
Message 1 of 7
Did try both format types and neither worked.
The USB that didn't work.
512GB USB stick that didn't work512GB USB stick that didn't work
Message 2 of 7
In which case worth trying exFAT, although no longer relevant in this case it seems.
Message 3 of 7
My Windows only allows NTFS and exFAT
Bob1950
Message 4 of 7
So the 512GB I had tried didn't work.
So I purchased a 128GB SanDisk Ultra for £12 from Amazon.
Arrived and I open and inserted it directly into the 4K TV Box.
Initialised with no problem. Surprise!
Looks like that size would record at least 100 hours of TV.
I think that there should be some way to ensure that the USB Sticks being used meet a specific standard as not all sticks are the same in delivering the correct results!
So I recommend SanDisk to overcome this unexpected problem for those just about to get a new 4K TV Box.
Now if there was a way to organise the menu at the top of the page as the recordings icon is almost the last item on the left so there is a bit of scrolling to get to it..
Message 5 of 7
Some larger sticks can have issued so I would stick with a 256gb USB Stick from a reputable make, Sandisk etc.
Message 6 of 7
If the stick is from a reputable maker then it should work. Try formatting in Fat32.
