IPlayers and apps
laked
Message 3 of 3
Why am I not able to receive TV apps or iplayers and only live TV?
Message 1 of 3
Also, is the box connected to the internet and fully updated ?
Message 2 of 3
Please see the pinned post at the top of the TV forum, here, if you have an older YouView box.
https://community.talktalk.co.uk/t5/TV/ITVX-and-TalkTalk-YouView-boxes/td-p/3010612
If its a TV Hub or 4K box, you will probably need to reset the box to factory settings from the menu.
Which box do you have?
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don’t worry there are plenty of ways to reach out if you need to speak to TalkTalk directly if you do not obtain the answer you require.
Please see the pinned post at the top of each forum page for a link.
