4k tv box
peterdg55
Message 3 of 3
Received my 4k box yesterday installed it this morning but there is no sign of google assistant. Which is the main reason I subscribed for it any ideas
Message 1 of 3
If you have the android TV Box, referred to as the TV HUB, then you can access the Google Assistant by pressing the MIC button under the HOME button.
Message 2 of 3
I'm assuming you mean the TV Hub box.
If so then help pages and in particular Google Assistant can be found here
https://community.talktalk.co.uk/t5/Articles/Using-Google-Assistant/ta-p/2924778
