Set top box streaming unavailable
Dedeye
Message 4 of 4
Talktalk Youview box Huawei DN360T won't connect to the internet, apps unavailable.
3 REPLIES 3
Message 1 of 4
You can try a full reset of the box via a Youview Maintenance Reset
If this does not restore the connection and the box has failed, then it cannot be repaired or replaced.
TalkTalk stopped providing these boxes over 3 years ago now and these boxes are now unavailable.
Dedeye
Message 2 of 4
Both methods. First experience with powerline adapters so everything carefully checked, including router. When that had no effect Cat 6 cable used from router to Youview box. Streaming unavailable whatever I did. Even left everything on overnight to ensure updates could down load.
TV service from aerial via box through connection unaffected.
Note that TV & box power supplies share a common extension which is switched off when power is not required.
Message 3 of 4
Is the box direct to the router with a cable or do you use powerline adapters ?
