on 02-04-2024 11:32 AM
Hi all,
I've just switched over to talktalk from Sky. I'm just setting up the tv hub and come to plug everything in and found our SkyQ antenna is a dual cable and in the back of the tv hub it's a single antenna port that doesn't fit either. Does anyone know if there's a device/splitter for this to work, or is sky dish not compatible with tv hub?
Many thanks
on 02-04-2024 11:34 AM
A Sky dish is not compatible, the Hub needs a freeview digital Aerial connection.
