yesterday
since changing to full digital service our BBC1 & BBC2 signal
is so poor we are often unable to view live TV
yesterday
These channels are over the air and will be unaffected by the broadband connection. There is freeview maintenance ongoing around the UK that can impact the signals.
https://www.freeview.co.uk/corporate/platform-management/planned-engineering-works
You should also connect the aerial direct to your TV bypassing any TV box and test the channels to see if there is any difference.
