Talk Talk box is frozen?
PaulOre
Message 3 of 3
My talk talk box is frozen on 1 channel and unplugging box does not worK, nor does the remote.
please can someone help?
Message 1 of 3
Hi Paul
Have you tried a reset of the Box as my colleague has mentioned.
Message 2 of 3
Have you checked the batteries in the remote?
Try resetting the remote. Details here
https://community.talktalk.co.uk/t5/Articles/TalkTalk-Remote-Control-Guide/ta-p/2204370
Try a soft reset of the box by holding the on button for around 10seconds until the box restarts.
There are other resets that can be applied to the box if these fail.
Try a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the support staff look at other alternatives.
Hope it works but if not then please let us know and support staff will get back to you.
Please note that TalkTalk now only supply non recordable ones., So it's best to try all alternatives if recording is important to you.
