3 hours ago
For about 3 weeks our bbc, itv and channel 4 hd channels have lost signal through our talktalk tv box. I originally put this down to the weather but it has continued.
This happened about 2 or 3 years ago and was fixed by talktalk sending a replacement box.
Is there a way to test the current tv box we have?
Pretty sure that the aerial isn't to blame, exactly as last time.
Andy
3 hours ago
Connect the aerial directly to the TV when the signal is weak and see if the picture breaks up rtc, this will give an indication if there is a weak signal from the transmitter.
