Loss of home apps itv x BBC iPlayer more 4 etc
Tufc8
Message 5 of 5
All the home channel catch up are not showing on screen  itvx. BBC iPlayer more 4  etc
Talk talk 4k box
4 REPLIES 4
Message 1 of 5
Good afternoon,
I'm glad to hear this and thanks for confirming.
Thanks also for your help @fr8ys  🙂
Message 2 of 5
Reset did not work. Turned everything off and started up again. Searched channels now back on Thanks
Tufc8
Message 3 of 5
Reset did not work . Resorted to switching everything off and going through channels now back thanks
Message 4 of 5
Is the box connected to the internet?
If not, try reconnecting.
If it is then a factory reset is probably the only option but if you have a usb stick for recording, you will use any recordings you have.
To reset the box turn it on, then press the button on the left hand side 5 times in quick succession. The box should then shut down and go through the set up procedure.
Let us know how you get on.
