talktalk tv hub
Hilary12
Message 5 of 5
I have a Samsung Smart tv with its own hub. Do I connect my talktalk tv hub to my Samsung hub using the hdmi cable?
4 REPLIES 4
Message 1 of 5
Good afternoon,
I'm sorry for the delay. Have you managed to connect the TV hub since your last post?
Message 2 of 5
The hdmi input ports are all on the one connect Samsung tv hub. They are marked as follows :-
port 1 (STB)
port 2 (PC/DVD)
port 3 unmarked
port 4 (ARC)
I connected the Talktalk TV hub to port 1
During the pairing process the TV told me the Talktalk hub was not recognised, it would not accept the model number I inputted.
Message 3 of 5
Hi Hilary12
Did you Try connecting the TV HUB to your samsung Hub or a direct connection ?
Message 4 of 5
You can try, otherwise connect it directly to an HDMI port on the TV directly if it has one spare.
