on 21-02-2024 01:16 PM
My new tv box is plugged in but doesn’t seem to have any power
on 21-02-2024 01:30 PM
Have you checked the socket is working. Can you press the button on the box, are there any lights on the box. The Android hub will have a little light at the front underneath, but you should see the glow.
