Netgem 4k tv box bbc channel issues
Boabby72
Repeat Guest
Message 24 of 24
<span;>I'm unable to view any bbc channel normally through my aerial. When selecting these channels the 4k box selects iplayer. All other channels work normally. I've carried out a full Netgem 4k box reboot/restart and also rescanned the channels, all to no avail.
<span;>Any ideas ??</span;></span;>
Robert Laird
23 REPLIES 23
Divsec
Message 21 of 24
Hi @Boabby72 got to admit, other than the antenna check I don't have much idea with the TV boxes as I don't have one. That admitted, when you initially setup the box does it ask you for your postcode?
My friend @fr8ys has a lot more idea and I'm sure he will pick up the baton for me.
Message 22 of 24
Hi Divsec
Reception on bbc is perfect when plugged directly into tv.
I've also since discovered that when I select settings on the tv box/ TV Channels/Select TV Region... I'm presented with GBR- Central Scotland - Glasgow but no option to select which.
I live in West of Scotland and have discovered that if I select for example my local BBC1 Scotland Channel which is 101 on the guide then no problem. But if I select Channel one shown as BBC1 on the guide the iplayer issue occurs ???
Any thoughts ???
Robert Laird
Divsec
Message 23 of 24
Hi @Boabby72 how is BBC reception with your aerial in the TV?
