New TV Hub "No Signal" screen showing
Sweetmary
Message 6 of 6
Daughter set up my new TV Hub last night. All worked perfectly. Tonight I had to use the old remote to get the TV to turn on. Now it's just showing the No Signal screen. I've checked all the cables are in. V Frustrating. Can anyone help?
5 REPLIES 5
Message 1 of 6
I'm glad to hear this 🙂 Please let us know we if can help with anything else 🙂
Sweetmary
Message 2 of 6
Thank You Karl. It's much easier to see now.
Message 3 of 6
To change the Guide, try going into SETTINGS, then ACCESSIBILITY then scroll down to HIGH-CONTRAST TEXT  and turn this option on.
Sweetmary
Message 4 of 6
Thank you Karl. That worked. Can I ask another question? Is there a way to change the colour on the guide? The blue on black is quite hard to see. Thank you
Message 5 of 6
make sure the TV Hub is turned on, then try the source button on the remote and make sure the correct HDMI channel is selected.
