New remote.
Talman
Whizz Kid
Message 9 of 9
Just a quick question. I have the new 4K box which I actually like a lot (I was not sure I would 😊) the only slight issue I have is with the remote. I often have to press the pause / home  button 2 or three times before it works.
I am not sure if it is related but the remote does seem to rattle a lot, which does not seem normal. I have other remotes and they don't rattle at all. It has done this since I received it.
Many thanks Dave.
8 REPLIES 8
Message 1 of 9
Good morning,
I'm really glad to hear this and thanks for keeping us updated 🙂
Message 2 of 9
Hi Karl
Just to let you know the new box arrived today!
The remote doesn't rattle😊😉 and works so much better!
Thank you once again for your help.
Best wishes Dave.
Message 3 of 9
Hi Karl
Thank you very much.
Best wishes Dave.
Message 4 of 9
Replacement on the way to you.
Message 5 of 9
Hi Karl
Thanks again for your response. The seems a bit extreme, but if that is what you need to do I guess at least I won't have to worry that the remote will pack up completely.
I will of course return the current box as soon as I receive the new one! Thank you so much for your help.
Best wishes Dave.
Message 6 of 9
We do not have provision to send a remote as yet, as we have no individual stocks of remotes, so I would have to replace the whole unit, box and remote.  Would you like me to do this ?
Message 7 of 9
Hi Karl
Thanks for your prompt response. I have the Netgem box.
That is what I thought! They seem to, or the ones I use do. I can switch channels okay, it just seems to be the home button and the pause that do not always work as they should.
Best wishes Dave.
Message 8 of 9
Is this the Netgem box or the Android box ?
Remotes should not rattle, but sometimes a little excess plastic can be inside that may have broken off.  Do all other buttons work as they should ?
