New TV hub
Scotia55
Whizz Kid
Message 6 of 6
Received new tv hub box couple of weeks ago and very pleased with it except for a couple of things.  Sometimes when I turn it on, the picture is very dark.  Need to turn it off then on again to fix it.  And the sound is a bit off with the picture.  I mean, when someone is speaking and it's not quite in sync.  Can I fix these couple of issues?
5 REPLIES 5
Message 1 of 6
Try the factory reset from the settings menu and let me know if this helps.
Message 2 of 6
Aye I found it.  And the sound option but doesn't seem to allow me to alter it.  Maybe do a box reset tomorrow.   I need some Netflix at the moment.   😁😁
Message 3 of 6
Yes, box settings. Haven't got mine hooked up at present but think it's home button, then up arrow to the cog wheel.
Scotia55
Whizz Kid
Message 4 of 6
Hdmi cable is okay.  Are you talking about settings for the box?  Where do I access those?
Message 5 of 6
I'd suggest checking the HDMI cable is fully connected.
Sometimes turning the cable round and plugging in works. If not then try a different cable if you have one.
As a last resort try a factory reset to reset the box in case there is a bug in the software.
In settings under sound, there is a setting to synchronise the sound and you can adjust by seconds.
Hope this helps.
