Our talk talk box is not working
ahowie
Message 4 of 4
Error code YVM302
3 REPLIES 3
Message 1 of 4
Hi ahowie,
The error YVM302 is for a low signal from the aerial.  Check the aerial at the TV for any signal issues in your area.  Try other channels incase it is just the selected channel that is affected, and do try a full retune if you still see the error.
Often it can be a poor signal from one specific channel.
Message 2 of 4
How are you getting on?
Message 3 of 4
Please see here for the help topic.
https://support.youview.com/youview-box/error-messages/fix-for-yvm302/
Also what happens if you plug the aerial directly into your TV? Do you get the channels or are they also affected?
What box do you have?
