Pause and resume live TV issues
NTremz76
Message 2 of 2
I've recently had an "upgraded" TV hub box due to the ITV X compatibility issue with the old style Huawei box.
However, when I pause live TV for any reason it is near impossible to resume playback without the picture and sound freezing and jumping. I get so fed up with it that I have to bypass the paused segment altogether and forward straight back to live TV.
I've reported the issue to Talk Talk who said that I have a box fault and will send a replacement. I've now set up the replacement box but same problem persists, this is obviously an issue with this new Google TV box
Has anyone else had this problem and is there anything I can do to remedy it?
1 REPLY 1
Message 1 of 2
I've tested mine for 10 minutes and it was working correctly approximately how long are you pausing for.
Also have you tested across different channels to see if one is better than another due to the freeview signals.  I've tested on New channels such as channel 236 etc.
