on 23-03-2024 01:09 PM
on 17-04-2024 02:39 PM
Hi MarionE
When setting up the TV Hub, if you left parental controls active then the box may at times ask for a pin code.
The default pin code is usually 1234 and for the older boxes it was 0000
See if this helps.
on 17-04-2024 02:20 PM
I have a new ITV hub and ITVX is asking me for a PIN. I cannot find where to reset it as I never had one previously. If it's to turn off parental control, how do I do that?
on 25-03-2024 07:53 AM
ITVX should not ask for a pin when using it, unless you have a parental pin set across the box in general, however when first setting up ITVX it may ask you to activate the app by entering a code on the website via a browser or your phone browser.
on 23-03-2024 01:16 PM
Try "ITVX PIN" on Google, other search engines are available.
